Raypak 406A
You are getting voltage to the gas solenoids in an uncommanded state. The board most likely senses the pv first and displays the pv output failure. You shouldn’t get any voltage until there is a call for heat. The pilot valve will open first followed by the main valve in a sequence. I would turn gas off and power the unit down and inspect/replace board.
Ok
I will
Thank you!
Is the heater a lownox heater? Does it have a blower? If not the pv and mv shouldn’t be energized early on. I suspect the high voltage lines were tied into the mv gas line, if that was the case I’m not sure what that would do to the gas valve.
Fast forward to about 40 mins in
Its not a lownox heater at all. I suspect that the problem was that at one point the MV wire was wired to the timer so that if the filter shut off, the heater would shut off. The electrician, for some reason energized the MV wire with 120V to each side. So 120V went back to the control board on the purple wire. This likely did some damage to it.
Reactions: Poolbreh
