Swimming Pool Products such as Pumps, Heaters, Filters, Cleaners, and Fiber Optics
www.inyopools.com
The Millivolt models are equipped with a self-generating electrical system in which the electrical current is provided by a pilot generator. No external electrical connections are required. The Millivolt model has manual controls.
The Digital model needs 120V or 240V AC power and has a digital control panel and electronic ignition.
Gas heaters are all controlled by a simple 2 wire low voltage "firemans switch" connection with an automation panel. The firemans switch allows the automation to turn the heater on and off to satisfy the temperature set in the automation. The heater thermostat is not used.
