Hi all,
Avid TFP follower here. 9,000 gallon vinyl SWG. Maintenance schedule is a cup or two of acid per week to maintain PH, never had algae, water always clear.
Was surprised to see our Raypak 156A gas pool heater not make it to see it's 4th season. We are in Michigan so it only runs about 4 months out of the year.
Heat exchanger corroded and leaked onto burners rusting out the burners and pilot. $1,000 worth of parts to replace alone.
Pool guy, heater repair co, and distributor all saying chemicals, that 99% of heat exchanger problems are almost always chemicals. Manufacturer says running at FC 5+ will corrode the exchanger and states this in the Raypak recommended levels.
Should I be running at different levels to help prolong the heater? Was this for sure due to chemicals? I want to get more mileage on the heater next time around, they are expensive.
FC 7
CC 0
pH 7.6
TA 70
CH 150
CYA 60
NA 3200
FC 7
CC 0
pH 7.6
TA 70
CH 150
CYA 60
NA 3200
