Hi everyone,
I am a new pool owner (pool was installed last year) and last year, the pool builder closed the pool for me. This year, I want to take this on. I am doing as much research as possible, following the TFP closing guide, etc. and I had a few questions that I am hoping you can answer for me.
1. When dropping the water down past the return lines, is 4 inches below the return lines correct? When I am dumping the water, once the water drops below the skimmers, it will not be able to continue to pull the water into the pump from them. Because of this, do I just switch to use the bottom drain only when draining the water out?
2. When blowing out the lines, what should my diverter values be set to? Also, is it better to blow the lines from the skimmer intake to the returns? I am not sure which direction would be better. As I understand it, the air would go from the skimmer (or return, based on the question previously) to the other end, but it would hit the diverter values (then pump, etc) prior, correct?
3. Even with the lines blown out, I should still add antifreeze, correct? I am going to be using the rubber plugs the PB used last year. 2 at the skimmers and 3 at the return. Do I need any other plugs? I plan to purchase a "Cyclone" blower for the lines.
4. Do I fill the skimmers with antifreeze as well? (Pool/RV antifreeze only)
5. The PB left what looked like an empty water bottle in my skimmer last year...do I need a Gizzmo for each skimmer or is there something better?
6. I was going to disconnect the unions at my SWG and the pump just to let it expand if needed. Is that correct or do I need to plug/add antifreeze there as well? Will also drain, open, and clean my DE filter. Anything needed for the heater? Based on the manual, looks like I pull the drain plug and shut off all the gas, etc. Should I store the pump and SWC indoors? If not, do I cover them not to let rain in the ports where it could freeze?
7. Is PolyQuat the only thing I need? I ask because my PB left what looks like almost full bottles of EZ-Clor Algaecide Plus and Metal Magnet floating in the skimmers. I am not sure why they were full unless they left them there in hopes to be used when opening up the pool.
8. What do I set as the "final stage" for my filter multivalve? I heard to perhaps leave the between two settings?
Ugh, I feel like I am almost ready but I am scared I will mess something up. The idea is very similar to winterizing our RV, but I just get worried with the equipment, etc.
Thanks so much!!!!
Thanks so much!!!!
