This is my first winter with my pool and temperatures dropped into the mid 20's last night in Austin. The Freeze protection in the Intellicenter did kick in and do it's thing. However, when I woke up this morning, the system was on spa mode and the water in the spa was at the light niche (almost empty) while the jets were sending water into the spa with the air blower on (see pic). Luckily, there was enough water in the spa to cover the drain so the pump didn't suck air! I have since turned off the air blower freeze protection as I'm sure this contributed to water loss.
I checked everything at the pool pad and there was a small leak between the IC60 and Intellivalve but definitely not enough to explain how low the spa water was. Strangely enough, this leak doesn't seem to be leaking anymore but I attached a picture that shows where the leak was coming from. The IC60 showed it was turned off due to cold water. As soon as freeze protection moved back to pool mode, I turned on the spillway mode to refill the spa. I previously had a leak in the light niche but plugged it with butyl tape at start up and thought this was the culprit, but I don't think it is anymore as the rate of water loss before butyl tape was high and the spa seems to be holding water (or losing at a slow enough rate it's not immediately noticeable).
I monitored over the next couple of hours while freeze protection was still engaged and it did still appear to lose water, but wasn't happening very fast. My hypothesis is it might have to do with the constant switching between spa and pool modes every 15 minutes. When the system went into spa mode, I watched the valves turn and the actuated valve circled in blue moves faster than the intellivalve in green. This video shows the time delay between valves... https://share.icloud.com/photos/0c1-1kTejIqTGiWX-Sa64yETQ
I tested this theory by going from pool to spa and back to pool again (2 valve switches) and it seemed that the spa water dropped around an inch. If freeze protection switches every 15 minutes, that means 4 switches an hour or 2+inches an hour. I'm guessing freeze protection turned on around 8:30pm (or earlier) so it was probably running for at least 12 hours by the time I noticed the issue. This would mean 2+ ft of loss over 12 hours not counting water loss from the blower that was also in freeze protection.
Questions:
1) Do you agree this is my issue?
2) There doesn't seem to be a leak at the IC60 anymore. Would the fact that the IC60 was turned off due to cold water cause the leak? Any other ideas since it's not leaking anymore?
3) If I accurately diagnosed the issue, is there a way to speed up/slow down either the standard actuator or the intellivalve?
Any other suggestions/thoughts?
Questions:
