Hello Pool Peeps,
Today I discovered a slight leak at my chlorine feeder (Rainbow Lifeguard Model 300, but it looks just like a Pentair 300). I went to fix it and only made it worse, as every line and fitting connected is literally crumbling away to nothing. I shut down the pool and need to take action.
Based on my observations it appears that this unit is probably original to the pool build, therefor about 22 years old. It doesn't look like it has been used for years (my pool guy puts chlorine tabs into the skimmer), so it either needs to be replaced or eliminated. If I can find caps to fit on the fittings on the intake and return pipes I may do that to eliminate the leaks, at least temporarily.
Can I remove this unit permanently, or should I replace it? I eventually plan on taking over full-time maintenance of the pool by myself, so if this is something I need I will replace it.
Next question - if I do need to replace it, will a Pentair 300/320 basically bolt in place of the old unit?
Thanks in advance!
Thanks in advance!
