21 footer
90
pittsburgh pa
Starting up my pool, had to add a ton of water so no surprise no fc.
Put in a gallon of liquid chlorine, tested about 4 hrs later, still read zero.
So grabbed a fresh gallon of liquid chlorine poured some straight into the tester, 2 scoop r 0870 and no pink either. The chlorine has a strong smell so don't think it's bad.
The powder is only a year old, and worked last year.
Ordered a fresh bottle from Taylor but extremely disappointed that it died like that, and I'm guessing on how much to add until it gets here.[l
mknauss
44,874
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
But should ut turn pink with 100 percent bleach or am I missing something.
At about 50 ppm, it will start to bleach it out. That is a few drops in a 5 gallon bucket.
So you do not have an OTO kit with the K2006. Test your tap water. Nearly all municipal tap water has chlorine in it.
Reactions: DThompson55
