Questions on Pump, Filter, Paramount Cleaning System
Suggest you first clean around the valve really good so you can inspect to see where leak is coming from. If from between lid and body, a gasket replacement might just fix the leak.
Maybe clean the area, take some closeup pics with and without the pump running and post them here..
Thanks for replies. I took apart and replaced the O Rings, and all fine now. Again, thanks everyone.
Reactions: mknauss and proavia
