I'm having an above-ground pool installed and I was hoping to run the electrical myself. I've received permission from code enforcement and also had my building permit approved.
1) Pool Bonding
I know I need to run a solid copper (#8) around the entire length of the pool and attach it to at least 4 points (posts) of the pool. That same copper will then connect to the pump and to the pool skimmer (drilling a hole and buying a stainless steel insert)
How far down/away do I need to bury this copper wire?
2) Electrical Outlets
Code requires the electrical to be 6' from the pool. I'm placing the pool 10' from the house so I was thinking about putting outlets right on the siding of the house. I mentioned that in my permit application and I didn't receive any feedback?
Is this allowed or even a good idea? It would prevent me from having to dig/bury conduit and electrical wire, etc.
I just need a shutoff switch which I guess I can just place above the outlet?
I'm not sure on the specific code requirements or even how to find out. The building inspector seems nice but doesn't want to answer any questions until he comes to inspect everything...
1) Pool Bonding
