When testing CYA it says to add water uhl you can't see the dot anymore. Well is it until you can't see the dot at all or just until it's cloudy and you can't see it clearly?
I've been using powdered stabilizer to try to raise my CYA a little bit and since my pool doesn't have a skimmer I don't think it really circulates the water all that well and so I'm worried because when I add the powdered stabilizer it sinks to the bottom so I'm wondering if there is a liquid form of stabilizer I can use?
I have used liquid stabilizer to raise my CYA in the past. However, ensure you shake the container extremely well before you begin. The ingredients will settle at the bottom of the container and you'll want to make sure it is mixed up before pouring it in. It is best to pour it into the pool in front of your returns. Then brush the pool thoroughly to distribute it.
It will go down if you remove water from the pool and add water without CYA to the pool.
It will go up if you add any products with CYA in it to the pool.
Test monthly or if you remove a significant amount of water from the pool.
