- Mar 30, 2013
- 18
So I have a 17k pool and bought the Circupool RJ-45. My controller is a Jandy Iaqualink 2.0. I was about to hook up the RJ-45 until a pool professional said when I have the spa running in spa mode it would produce too much chlorine since the RJ-45 does not talk to the Jandy system. He mentioned if I used a Jandy cell (Truclear I believe), I could set the cell to produce at a lower amount when in spa mode and then at a higher rate when in pool mode? Is this really an issue? The RJ-45 is so highly rated and long lasting i was excited to buy and install, Conversely I can't find much good about the Truclear system (Jandy) with many saying it is finicky, stops working, or doesn't produce enough chlorine.
Any ideas or thoughts are appreciated...
