Question about replacing Pentair Pump
ChadS44
20
Missouri
Hi everyone, I needing to replace an older Pentair variable speed pump (011018). I’m looking at a newer Pentair VSF pump (011056). My question is, can I simply unscrew the plumbing and switch this out without having to raise or lower the incoming or outgoing pipes? I can order this online, nobody local has it available. Hopefully it’s an easy replacement, as local pool companies are booked out for weeks. Thanks for your help.
mknauss
42,184
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
A straight swap. Assuming you have pump unions. You may want to replace the pump side of the union, but they may be fine when unscrewed from the old pump.
Jimrahbe
22,243
Bedford, TX
Chad,
Show us a pic of the pump.. I really doubt your pump is installed with pump unions.. They look like this..
If you don't have unions, you will have to cut the pipe in order to get the old pump out.
Assuming that you do not have unions, I would strongly suggest that you use them to install your new pump.
ChadS44
20
Missouri
Chad,
This is what I’m working with. Think these will unscrew?
mknauss
42,184
Laughlin, NV
Fiberglass
No. They will need to be cut off and the system rebuilt with pump unions.
Jimrahbe
22,243
Bedford, TX
Chad,
They will unscrew from your pump, but only after you cut the pipe..
Buy the unions and it will make the install very easy.
ChadS44
20
Missouri
Thanks. So just to clarify, will I need to rebuilt back to these existing unions that I’ve highlighted in red? Can I just cut the vertical pipe and use a coupling at the spot I’ve highlighted in yellow?
mknauss
42,184
Laughlin, NV
Fiberglass
Yes. That will work for the pressure side. The suction side has a check valve in the way. Rarely do pool systems need a check valve on the suction side, so you might consider removing that and then you will have room to rebuild and install the pump union.
ChadS44
20
Missouri
Thanks. I believe the check valve is there because of the incline from the pool to the pump. I was having issues losing prime.
alf1096
50
Wichita Falls, TX
Jandy Aquapure 1400
or just replace the motor....cheaper and no plumbing involved.
