I'll be setting up a new 15x48 metal frame Intex pool soon and would like to add vinyl flaps to cover the tee connections like @beggehorn outlines in this post: Idea to help keep water out of Intex rails and t-connectors....
My question is, he mentions that the holes in the walls at the tee connections serve as a safety overflow point that he doesn't have to worry about because he has a through-wall skimmer add-on. I don't plan on adding a skimmer, at first at least, so would it be a problem to cover those holes?
I realize that with the holes covered, the pool is bound to fill up to the brim after a good rain or two, so maybe the flaps aren't a good idea without a skimmer installed? If the overflow feature is a necessity... how crazy would it be to cut some sort of hole just underneath the top rail between two uprights to serve as an overflow? Thoughts and guidance appreciated.
