I've made a few posts detailing the rust issues I've experienced with my Intex pools and am brainstorming some ideas in how to best prevent water from getting into the ends of the horizontal supports. My Ultra Frame uses plastic t-connectors with integrated locking pins. With my last Ultra Frame, water got into the connectors and inside the holes at the bottom of the poles where the pins lock causing rust to very quickly eat the poles to where they needed replacement after only two seasons (the vertical legs only lasted one...).
This year with a brand new pool, I've used silicone to seal the bottom of the legs where they join the cups. I also plan to use 2" self-fusing silicone tape to wrap the top of the legs where they connect to the joints (being sure to completely cover the holes/pins).
Because of the complex geometry of the t-connectors where the horizontal rails connect, I've been hesitant to attempt a silicone tape wrap. But I had an entirely different idea this morning...
Because I have a through the wall skimmer installed, the hole at the top of the skimmer (which is lower than the "windows" in the liner where the t-connectors are positioned) serves as my overflow point. I realized that while these windows may serve a overflow safety function for some, the through the wall skimmer makes this moot.
Looking at the liner, I though how hard would it be to cut a flap of vinyl and glue it to the inside of the pool (being sure to also glue it down to the vinyl hanging over the top rail) and then hang it over the edge? The flap hanging over could easily be secured to the leg with a zip tie, or even a magnet.
I'm really tempted to try this... If I did, what would be the best glue/adhesive for a permanent, waterproof bond (vinyl patching cement??).
Thoughts?
Thoughts?
