Hi there.
Re:
Your ideal cya for a slam is around 30 ppm cya, in terms of how much bleach/liquid chlorine you'll need to maintain slam level. BUT pool stores are often wrong on cya -- plus its also possible to slam at a higher rate if need be.
I'd rather see you do your own cya test when your new kit gets in -- once you've mixed it, you can practice reading it a few times to get comfortable.
Knowing and controlling the cya level is the true key to TFP and why it works. SO for the immediate moment, use the [FC/CYA][/FC/cya] to determine what your
SLAM Process level would be, then use the PoolMath calculator to figure out how mch liquid chlorine/bleach to add...and add that once for now so that there's some decent FC working in the pool to help stave off getting worse...even if your cya level is actually higher.
Tomorrow, just add a gallon (to add a few ppm ...you have a pretty large volume pool) to help maintain -- what day does your test kit arrive? This will help you not go backwards for a few days, but when the kit comes, you can determine how many patrial water changes or what percentage of change you need to do to get into a better cya range for a full slam mode.
Part of the reason I want you to wait on the water change is I'd like you to check your home/sale records to see if you have iron in your well -- and if so, how many ppm the last known report says.
If you do, there are a few things to consider regarding a water change and slamming and ill walk you through the options. You've gotta slam to get clear, but we need to have an idea if the metals are high enough to tint with new raw water.
Report back on the well situation and I'll fill you in a bit more tomorrow
Don't want to drown you in details at the moment and want you to absorb the immediate steps first that I linked to
Cheers to clear...its just around the corner.
