gcates said:
So does that mean that as the summer goes on and my water gets used and I replace it, that as long as I'm using liquid chlorine that my cya will start coming down?
Can I start tomorrow?
Yes and Yes.
OK Here is a plan:
1. Measure your pH and FC levels
2. Adjust your pH to 7.5 (use the poolcalculator to determine how much acid to add)
3. Wait and hour and confirm your pH is where you wanted (pH test not valid when FC>10)
4. Add bleach to reach a FC level of 23+ (based on poolcalculator)
5. Wait about an hour
6. Measure FC
7. Repeat steps 4-6 until you pass the 3 tests in the Pool School Shocking Article (this may take days or weeks)
Going over 23 is fine ... in fact to start you may want to go higher as the goal is to keep the FC level > 23
After a few hours, the FC should not drop as quickly (especially overnight) and you can extend the time between FC adjustments.
Notes about poolcalulator.com:
Be sure to enter your pool size at the top, and pick TroubleFreePool, Bleach, and Vinyl at the bottom.
And please add pictures of your progress
