Here's a page that another members showed me once I was first starting with the BBB process. Calmed my wife's nerves a ton....and made her chuckle too with the wording.
http://www.poolsolutions.com/gd/best-gu ... chart.html
As for your results.....I would think (although I'm not 100% sure) that adding some fresh water after you've taken the test would toss the results off. I'll let others chime in on this one. I just re-read the thread some and saw the "questions" about the CYA levels on 4-5 and the amount of stabilizer you had added. It's been several days' since you had done this and it maybe a good idea to run another test to get an accurate CYA result. There's a chance that you've been shocking at to low of a level causing the process to take longer than it should. A TRUE CYA result at this time can help us determine this.
