My booster pump is screeching which appears to be bad bearings from my read of the forums. What I can't tell (I am probably just slow) is whether the bearings that need to be replaced are in the motor or in the pump that is bolted onto the motor? I want to be sure I get the right parts but it would seem logical to me that there may be bearings in both the motor and the housing. Also, it only seems to screech under load. When I took the housing end apart to see if there was a pebble or something stuck in there. I turned it on briefly when it was apart and it made no noise. I thought it was magically fixed but when I put it back together it started screeching again.
Thanks
Thanks
