We uncovered our pool a few days ago and need to have water hauled in to raise the water level several inches in order to hook up the pump and filter. I wanted to get an idea of where my cya was at before diluting it further. Using room temp water (it actually sat inside the house for two days) I did the cya test according to kit directions, mix, wait, mix again, and I filled the view tube all the way and could still see the dot. The sample wasn’t very cloudy at all. I have done this test a number of times before so I know how it usually looks. My test kit is almost two years old. Could the testing materials be too old?
The pool water is very clear. FC was 3, a bit low after a couple sunny days, so I added LC and circulated with my robot and now it’s 10. We put the solar cover on to slow the burn off from the sun until we can get the pump and filter going. Which brings me back to the water delivery arriving shortly!
So should I assume I have no cya? I believe my level at closing was 40.
