We purchased a new (to us, 1984 build) home this month in Central Texas (just south of Austin). I wasn't looking for a pool but the right home came along and it happened to include a pool so now we are first-time pool owners. I'm what I would consider a fairly well capable DIYer so I certainly plan on doing the pool upkeep, repairs, etc. myself.
The pool is a 15,000 gal plaster in-ground kidney with a Pentair FNSP 60 DE filter, Pentair 320 Chlorine tablet dispenser (I plan on going to liquid chlorine asap), and 1HP Sta-Rite circulation pump on an old-school mechanical timer (currently broken so the pump is running 24/7 until I can fix that). Water is clear and chemistry levels are in range for the time being. In addition to the circulation equipment, the pool is plumbed for a cleaner system. It has the port at the water line for a pressure side cleaner. There is a dead Pentair Boost-Rite 1hp booster pump in the pump room as well as an equally dead 3 wheeled Polaris pool cleaner (model Uknown since the decals are long worn off). The Polaris clearly lived a long hard life. It's body is full of holes from repeated scraping the plaster and it's got loose parts. Not even sure it's complete so I don't expect it's worth salvaging.
I'm getting a lot of dirt settling at the bottom. I expect from the dust in the air in Texas this year. I've been sweeping it into the main drain and it seems to be slowly filtering it out although it appears to be redistributing into the pool overnight. Could be more dust, or could be the filter isn't working properly and the dust I sweep into the main drain is recirculating back to the pool. Filter is reading about 10psi currently so it's either clean or not working. I have not opened the filter housing yet. It's on my list to open the housing, clean the DE screens, and reapply DE to the filter then I know the status of the filter.
So here is my question. I'd like to get the cleaner system working on the pool to assist me in removing this dirt. Is it worth replacing both the booster pump and Polaris with the same products or should I be considering some other options for the pool since the entire cleaner system is toast? Electrical, pressure side, suction side, cordless, wifi... so many options.
Thanks for the advice.
Reuben.
Reuben.
