Pump wiring for timer
Bigfellor
59
Texas
CircuPool SJ-40
Hello all. Is it possible to wire this pump to this timer to run at high speed for certain hours then low speed on the off hours?
Honeywell Home TI040/U Industrial Weekly/Daily programmable Indoor and Outdoor Timer, Gray https://a.co/d/gziRdTI
Or do I need a different timer?
That timer won't switch speeds, it is a "single load" switch. Since a two-speed motor is, essentially, two motors in one case, you need a two-speed timer. That is one that will disable one speed while enabling the other and has the ability to NOT have both on at the same time. Since you are using 115v, get an Intermatic P1353ME electronic clock that will do it when set to the proper mode. This clock will run on that voltage. Don't believe there is anything else readily available that will.
Thanks I'll check into that.
