Hello,
I just swapped my pentair superflo to a pentair intelliflo and before I power on anything I need to verify that my old pump was wired for 230volts. What is the most straightforward way to check this? If I do have 120volt setup how hard is it to wire in the pump to run at 230volts? Im not an electrician but I can do the wiring, I just need to know the process.
