Earlier this afternoon I noticed the pump making a weird sound so I went to check on it and low and behold there’s a suction side air leak and one of the unions cracked and so water isn’t cycling through the pump. I went to 3 different pool supply stores (all same company) and none of them had any unions…so they sent me on my way with zero solution.
So I guess Amazon, it is. But my question is, I need to cut the pvc that this cracked union is connected to in order to fit new one on, reconnect the pvc pipe to the pipe I am going to saw it off from and then screw the new union to the pump, right?
TIA
TIA
