Last year I replaced a 2HP SuperPump II with a 1.5HP variable speed pump as a bit of a stopgap until this summer. The 1.5 is not quite enough to run the pool efficiently and I'd like to replace it. Being able to schedule routines on the pump itself is nice and saves money so that the whole pool controller doesn't need to be replaced, but it sure is cumbersome. I'd like to be able to easily adjust the pump speed, as part of the return runs a waterfall, and I usually have that running while we are actually in the pool. I saw that there is a wifi adapter for the Vgreen Century pumps, but I couldn't find any full pumps that have that motor, so maybe I'd need to build it all myself. Anyway, does anyone have a recommendation on an easy to control variable speed pump that is 2+ HP?
I may replace my pool cleaner (currently pressure-side) with a robot and in the near future maybe also the pool heater. I'm having a hard time deciding if they all need to work together and I should just replace the whole control panel, or if I should piece it all together myself.
Thank you so much! While we wait for warmer weather, at least my head is swimming!
