- Mar 20, 2021
- 17
- Plaster
- Pentair Intellichlor IC-40
Moved from here.
I have a similar problem. I have a Pentair IntelliCenter with 2 VS Pentair pumps. I have programmed my spa so that the pump runs at 2000 rpm when the heat source is not on, but when the heat source kicks in the speed jumps to 2800 rpm. Works great. But when I try to set my pool up similarly I have a problem. I want the pool pump to run at 3000 rpm when the heat source is not on and 2600 when the heat source is on, but it always runs at 3000 rpm even when the heat source is on. Is this the same problem as Alaxon has? The pump will always run at the highest speed? But then why does my spa work properly?
TIA
TIA
