- Jul 27, 2017
- 82
- Plaster
- Pentair Intellichlor IC-40
Just yesterday I was staring at my TFP clear pool in amazement at how clear the water is, it always blows my mind how following the simple processes that TFP teaches and preaches can deliver such water clarity when others who spend more time and money struggle mightily to get to this result. And then, just 4 hours later, I could barely see the main drains at the bottom of the deep end. So I’m back, asking for guidance and advice.
The story:
I know exactly where the cloudiness comes from, it’s issue #1: DE being pumped out of my filter And through my waterfalls into the pool. In seconds, the entire pool is cloudy. This has happened to me now 2x and I’ve been racking my brain trying to figure out how on earth it could happen. See the attached photo for the layout of all my pool equipment. As. You can see - the 3 big pipes in the middle bottom of the photo are lines that connect to the main drain and the 2 skimmers. They feed the main pump and the waterfall pump. You can also see that the waterfall pump (on the left side in this photo) pulls directly from those lines 3 main lines and does not pull from water going through the filter. So, how on earth is it possible that DE is getting out of the filter and over to my waterfall pump? What I noticed this time, is that issue #2: the main pump had shut off for some reason. This makes me think that when the main pump shuts off, the waterfall pump is pulling so hard it starts pulling water backwards through the returns, through the heater, through the filter, through the main pump and over to the waterfall pump and viola, we have DE coming out of the filter over to the waterfall pump. This is the only explanation my meager brain can contrive, which tells me that maybe the check valve just above my main pump is bad.
Questions:
The story:
Questions:
- Stop DE through waterfalls: While I know it’s happening, I think that there should be something stopping the water from flowing the wrong way out of the filter into the waterfall pump (the check valve sitting above the main pump. Would love anyone’s advice here.
- Stop main pump from shutting off: Why is my main pump turning off?? Just this morning I got up, it was running as scheduled. I was out there brushing and running the robot and then for no apparent reason it shut off. Sometimes this doesn’t happen for months and then it will happen a few times a day. (By the way, we did recently have a power failure if that would give anyone any indication). it’s driving me crazy to randomly notice that the pump has shut off.
- Test: Any tests you think I should run to make sure everything is working properly?
