pump setting?
dxn1261
1
tampa, fl
Hayward Turbo Cell (T-CELL-5)
hello im new here and this is my first post! I have a 8300 gallon pebbletec type pool with a Hayward turbo cell (t-cell-5) and in floor pop up cleaners. my question is what should my pool pump settings be on?
Which pump do you have? A VSP?
Virtually all pools are "custom" pools so the settings for your pool also have to be considered "custom."
With in-floor cleaning you will need to find a speed that allows them to work for as long as it takes to clean, then run a long, slow, filtration cycle that can give enough flow to the SWG to keep it on. You find a speed that does that, add another 100-200 RPM to allow for a dirty filter, and you should be good. The cleaning speed will also allow the pool to skim, so it is good.
