- Jun 15, 2019
- 24
- Vinyl
- Pentair Intellichlor IC-40
So I’ve read many posts and article about pump run time and still trying to decide what’s best. I understand the principles that running the pump only as much as needed to generate enough chlorine is the bottom line with preference for clearing debris as the next reason to run longer. In my scenario, assuming I’ve done my math correct, the PB set me up to run 2950/3hrs, 1700/6hrs, 2550/3hrs for a total of 12 hours. I’ve been running 24/7 this past week and a half as I’ve added salt and stabilizer in preparation of turning on SWG. I did really rough(conservative) numbers using the pump flow chart to determine flow at different speeds and then used pump watt usage on display for calculating running costs. The PB setup would hypothetically filter 28,800 gallons in 12 hours. I could run pump 2950/2hrs and 1700/22hrs and filter 46,800 gallons for almost the same energy cost. Either way, I plan to only run SWG as needed to maintain FC levels. I kind of like the idea of running 24 hours a lower speed for the same energy cost. Am I missing any downsides to running this way vs how PB set me up? Again numbers are ballpark, which I know is not ideal.
