M,
The idea that you have to pass your water through the filter x times a day is just a myth made up by people that don't really understand what the filter does...
Chemicals keep your pool clear and sanitized.. The filter just captures the junk that falls into your pool.
I suggest that you run at the lowest RPM that keeps your pool skimmed.. I run my VS pump at 1200 RPM, most of the time and don't care if I turn the pool water over or not..
And... if you think about it... once the first gallon of water has passed through the filter and goes back to the pool, what prevents it from going through the filter again.. The more you run the less likely that all the water is going to be run through the filter anyway..
The whole point of running a VS pump is to run slow and save on the electrical bill..
What does most of the time mean? lol I've been reading a lot and I understand it's trial and error but I dont' even know if I know what a successful trial looks like vs an error. I know we are running ours too much 10 hrs at 2000RPM and 12 hours at 1000RPM. I read somewhere it is better to not have the pump priming a lot so VSP run better if always running like a compute. Anyways, I don't get a lot of debris in my pool. We are running for skimming of like pollen (which never seems to go away) and to run long enough for our SWG to produce what it needs to and for our heat pump which I can't seam to get to work now either (again -- Hayward victim here). So do you run 1200RPM 24 hrs a day? What conditions would make you run a different RPM?
