Hello, so I just replaced my pump on my hot tub, direct replacement for the most part so it was fairly simple. However, my old pump had a barbed connector connected to one of the drain plugs that did not fit in the new one. The only one I can find for that pump after a short search has a wrong tubing size. MY question: what is this for and why do I need it? The answers from Google are all over the place and so are the opinions on if I actually need it. I have heard it primes the pump, purges air to prevent airlock (which I can do manually if needed) and prevents water from freezing in the pump (which doesn't make sense).
Can the experts here tell me what that inlet/outlet is for and if I actually need it?
