They guy who closed our pool showed up unannounced back on 10/13. That started a whole chain of events that have been difficult at best, a disaster at worst. This was a job I did myself for many years, always made certain I met the guy myself once I hired the job out, and this was the first time (because of his panicked arrival) that wife met him.
Out of that confusion, no one turned off the main breaker and the pump, on a timer, has continued to run unattended for 10 days. I discovered it by accident when I wandered out in the back yard earlier this morning. Plenty of blame to go around here...so that's not the point...my question is the extent to which we may have damage now, and to what extent that damage may be.
The output valve was set to 'closed' and the input valve from the pool was left in the 'blocking the main drain' position, meaning that it was 'pulling' (if at all) from the skimmer side.
I presume that we may have burned up the pump...that's really almost a given in my book.
The salt generator was 'energized' through this process, but with no water running through it, is it likely to have sustained any damage?
My biggest concern is the pump pulling on the underground lines for all that time. Rather than shutting off the intake valve to both sides, the guy had it set to block the return from the main drain...but this means that the pump has been 'pulling' on that 1 1/2 inch PVP pipe for 12 hours a night...for over 10 days. Is there a probability that it would have collapsed that line (or even worse, the main return from the bottom of the pool) underground?
What about the winterizing that was done? Should I go back and winterize the entire thing again?
Thanks in advance for any advice...
Gene
Gene
