HI. New to pool caretaking. Just opened. Pool guy cleaned the filter and added DE. The pump runs for an hour or so at about 10 psi. then it rises to above 15 to as high as 20 psi. so I shut it down. I let it rest for an hour or so, restart and pressure holds at about 10, but then rises up to over 15 so I shut down again. Did a backwash, same result. I keep the skimmer clean. Also need to add something to kill algae. Could the algae be a cause? Advice appreciated.
