Ok so we seem to have fixed the groundhog hole in our pipe, but now when we turn the pump on, it won't prime.
Other info:
1. Pump primes when filter is set to backwash.
2. Water level is high enough.
3. I changed the pump basket o-ring.
4. I closed both of the skimmer valves, one at a time, and there is no change.
5. I checked for clogs before the pump filter and after the skimmer lines join back up.
6. No clogs in skimmer baskets or pump filter basket.
7. Weirs are fine; just getting very little suction (even with only one skimmer line open) when on filter mode.
I think that's everything. Like I said, it WILL prime on backwash mode. I have not tried other modes yet.
ETA: recirculate does the same as filter. Rinse *works same as backwash. 0 pressure on filter when in filter mode even though I can hear water running into the filter. Impeller and impeller o ring appear fine - no clogs or cracks.
Other info:
