Pump not starting
Nordygirl1
1
fontana , ca
Pentair Intellichlor IC-40
I have a pentair remote and it stop communicating to my pump. It keeps saying lost communication. I have turned off the breaker in the pentair and even at the main breaker and still wont connect. Any suggestions. Pump and system is only 2 years old .
NG1,
I assume you have an EasyTouch or IntelliCenter automation system.. Is that true?
If so, your pump should just run automatically, you should not have to push a button to turn it on.
Do you normally have to manually turn on your pump??
Show me several pics of your equipment pad so I can see the automation system and the pump, so I can tell what kind it is..
Then we can figure out if this is a remote issue or system issue.
Reactions: Texas Splash
