- Nov 7, 2018
- 1,049
- Plaster
- CircuPool RJ-60 Plus
This morning, I installed new cartridges into the filter. I debated cleaning the existing ones, but knowing how the previous owner had blown off all preventive maintenance around the rest of the house, I had an idea that all-new filters would be a prudent move. Replacement was no issue..and as I suspected, the old filters were nasty and absolutely covered in debris. The filter pressure before was 25 PSI and after is now 15 PSI. All good, right? Well...
Now the pump is making one helluva a noise. I would almost think that it's the sound of a bearing failing (similar to a gravel crunching sound). Also, the return flow to the pool...well, it's pretty crazy...almost like a spa. I think I am getting a full turnover in about 30 minutes (not really, but the flow is noticibly increased). I am not able to put the motor into low speed (that's another thread) so I am unable to tell if this sound would continue.
I am confused as to why a very quiet pump (under restricted flow) is now so freaking noisy. Any ideas?
