G
Guest
If that's not it, I would try to run 10 awg (stranded). Your short run test, the current dropped. I really think you have a problem with your mechanical timer. Good luck!
captjake said:What am I doing wrong...??!!! Help...!!!!
captjake said:The conduit can definitely handle it, but like you said, hard to find stranded ROMEX. OK, off to Lowes. Will report back later. Thanks.
bk406 said:No such animal as stranded Romex. Also, you cant run Romex in conduit like that. Romex is not rated for wet areas, and conduit run outside whether buried or not is considered a wet area. The proper wire to use is stranded THHN wire.
salp said:bk406 said:No such animal as stranded Romex. Also, you cant run Romex in conduit like that. Romex is not rated for wet areas, and conduit run outside whether buried or not is considered a wet area. The proper wire to use is stranded THHN wire.
This is incorrect, you can get stranded romex in #8/2 and that's why I told him to cut the insulation off it works...
salp said:I agree, he is trying to troubleshoot the problem and do a quick test. .
salp said:I agree, sometimes it can. No worries! Hopefully it is the wire, he has tried everything else...
salp said:This is true, he might be able to use the existing one, but if you are buying new, you should probably buy all three. Dam, if he is going through all this trouble, he should run 220V and get a different pump...
captjake said:No stranded ROMEX available at 3 stores. Going for the regular THHN. Not so cheap at $80 a coil x 3.
