Bearings usually go bad due to a leaking seal. For a seal to go bad in that short a time is usually the result of bad water chemistry or running the pump dry. Occasionally the seal-plate can be damaged, but that is rare. A motor shop can easily replace the bearings in the motor. I've done it several times and I'm not a motor shop. Variable-speed motors are much easier to work on than standard motors. There are warnings about the strength of the magnets that should be heeded, but the job is a straight forward bearing replacement. If the drive is functioning correctly, it is worth a try.
