Hi all,
Need some help please!
When I turn off my pump, it loses prime. My pump is quite far from my pool, and probably several feet above the water. However, I gather this shouldn't be a problem and it ultimately means I likely have an air leak on the suction side, ie somewhere between the skimmer and the pump itself.
I've gone through a few of the suggestions I've seen on here:
- Replaced O-ring on pump, cleaned lid and used a silicone lubricant from the pool shop
- Used Teflon tape around the drain plugs to help the seal
- Ensured pump lid is tight
I tried putting foaming hand soap (couldn't find shaving foam!) around the lid and drain plugs and didn't see anything obvious.
I listened for an air leak around the pump, but the noise of the water rushing away was too loud. If anything, there may have been some noise from the filter but that's obviously not on the suction side. That's another problem, I guess. But not my immediate problem.
I tried closing the valve before the pump after I switched off the pump. This seemed to stop the water rushing away after it was closed, aside from the amount that managed to disappear before I could close the valve. This suggests to me that the air leak must be after the valve, ie around the pump itself, presumably either the lid or the drain plugs. Does that sound right?
If that's the case, any thoughts on how to proceed with figuring this one out? I'm not too sure where to go next and how to do it, but obviously this needs fixed...
This is a system I inherited when we moved into the house, so my knowledge is limited.
Help please
Thanks!
Graham.
Help please
Thanks!
Graham.
