As far as know, everything was running fine until I went to clean the pump filter/basket about an hour ago. After cleaning it, I turned the pool back on but the pump displayed an error of ‘Over Voltage’. I did several combinations of flipping the breakers, turning the pool on/off, and hitting the reset button on the pump over about 20 minutes. Sometimes it would run for 30 seconds and sometimes for 2 minutes. It has seemingly been running longer now bt shutting off… maybe because I let it start a few times to prime itself. It just ran about 10 minutes and cut off then back on. However if I try to turn on the heater, the pump stops within a minute, tries to restart, then stops after a few seconds.
Obviously I’ve never seen this behavior. The pool is less than a year old and my experience with any of this started back then. Any help would be appreciated!!
