Hello, we have had our pool for a couple years. Recently started doing the service myself to try and save some money. All has been well so far except for the mystery that currently presents itself.
-Salt water pool, about 21K gallons; currently chlorinator is off due to low water temps
-Pool temp about 40 - we live near charlotte, its cold
-Chemical balances seem to be good based on testing from Leslies
Problem: Jandy VSP running at normal schedule, no changes. The intake flow into the VSP pump is resulting in only the basket filling half way. Usually it is all the way full with a small bubble circling on top. One, i think, key thing i noticed when i discovered this was that one of the skimmer baskets was floating and not down in the bottom of the skimmer box.
There appears to be enough water in the pool, but am currently adding more. I suspect there may be a clog in the the skimmer line. Have tried to switch to spa mode etc to move the valves around. I was going to try and snake the skimmer line but the water is so cold I cant seem to keep my arm in the water long enough to figure out how to get the snake into the pipe. Have already let any air our of the filter as well. Also thinking could be an air pocket somewhere. i have adjusted the VSP from 3000 to max 3450 in hopes that might "move something along"
Anyway, pretty new to this, I hope i gave all the information needed. I am mainly looking for suggestions and also wondering how big a deal this is for now given its about to plummet in temp here in charlotte tomorrow-tuesday. there seems to be enough water getting into the basket that the the VSP intake to the large filter is still collecting water so i don't think i'm at risk of frying of the unit. freeze protection is running fine when needed.
Thank you!
Thank you!
