Hello! Wow, this is my third post in one week. Things aren’t going so well. I’m still SLAMMING a week later so my pump has been running 24/7. Yesterday I cleaned out the pump basket. I believe I didn’t prime the pump enough when I turned it back on. I thought I did because I had air bubbles coming out like normal and thought the return lines were working properly. Long story short, i think the pump may have run dry for a bit because I came back a short time later (I honestly can’t remember how long) and I had to re-prime it because the jets weren’t flowing.
Last night when I went to do my OCLT test I noticed the pump was off. The breaker was fine. If I manually switched the pump on/off it did nothing. I had to wait until the timer shut off at 9 pm. Then I turned the timer back on to run all night, and manually flipped the pump switch off/on. It turned on and ran all night (at least it was on this morning so could have been intermittent?)
This morning around 9 I noticed it was off again. I had to do the same thing with the timer - on/off, then pump off/on. It did it again a few hours later. There is a slight burning smell around the pump area but could be from the AC?
I feel like I might have killed the pump by not having it fully primed. Or running it 24/7 hasn’t helped.
It’s a Hayward 1 HP super pump. Model number SP2607X10. The previous owners’s paperwork says it was replaced in 2014.
Any ideas? I’m new to TFP and basically a pool newbie. Thanks!
