Planning a pump and motor replacement this winter and have been playing with some of the online calculators without much confidence.
As I live in CA I will be going with a 2-speed motor and am trying to determine the ideal motor size. Not sold on variable speed pumps due to reliability and cost.
Currently I have a 2hp single speed motor with a Pentair Wisper Flow pump and run the pump now 4 hours per day utilizing only the skimmer, no bottom drain, and keep the pool clean with a Maytronics robot. No water features or heater or SWG or bottom drain or suction side cleaner, only one skimmer and two outlets.
I am unsure of the pipe size underground but the 2" inlets and outlets at the pump are stepped down to 1.5" PVC. I was told that there are copper lines underground but have not done any excavation to confirm this as it is under brick decking.
I know I can replace with a 2hp 2 speed with the idea of using the lower speed most of the time and having the 2hp option. Can I downsize to a 1.5 hp 2 speed? This is what I am attempting to calculate.
My Pentair DE filter is 48 sq ft and it lists the max operating pressure at 50psi and I currently am operating at 25psi when clean using the 2hp motor.
The label on the filter lists the GPM at 120 and I'm not sure if that is max flow or the recommended flow rate. Any ideas?
My plan is to tap the inlet and exit lines and insert a vacuum and pressure gauge to measure head, than target my GPM to determine motor size. The head calculators I have explored involve a lot of assumptions that leaves me guessing.
Any thoughts or ideas would be welcome, thanks.
