Results 1 to 17 of 17
Thread: SuperFlo VS RPM vs Watts
    For anyone that has the Pentair SuperFlow VS 1.5HP pump, would you do me a huge favor? Can you run your pump at various RPMs from lowest to highest and let me know what the watt use is at each setting?
    That would be super-helpful for anyone looking into a VS pump! These numbers exist here for the IntelliFlo 3hp pump, but not for this one, thanks!
    16 x 32 18,000 gal IG vinyl pool. 1.5HP SuperFlo VS pump. Hayward C4030 425 sq ft cartridge filter. Hotspot FPH heat reclamation pool heater.
    Apr 2015
    Richland WA
    56
    Re: SuperFlo VS RPM vs Watts
    I just ordered that pump the other day. It's supposed to be here Friday and I plan to install it right away.
    If you haven't got your answer by then, I'm sure I'll be testing many different settings over the weekend.
    24,000 gal in ground, Gunite, Sand filter, Hayward 140,000 btu heat pump, Pentair Superflow VS, Polaris pool sweep, TF-100 test kit w/speed stir
    sounds great, thanks!
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    500 rpm - 77 watts
    750 - 108
    1000 - 143
    1250 - 186
    1500 - 246
    1750 - 336
    2000 - 450
    2250 - 596
    2500 - 783
    2750 - 1000
    3000 - 1260
    3450 - 1950
    Your numbers may vary depending on you plumbing. I have 1.5" ridgid. PVC
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Those numbers are really close to the 3hp IntelliFlo pump from Intelliflo VS (011018) RPM / watts to GPM
    RPM for RPM, I would have guessed a pump half the size would have used half the power. Hmm.
    (copy-pasted from the IntelliFlo thread)
    RPM WATTS
    750* 100**
    1000 140**
    1200 160**
    1400 200**
    1600 290
    1800 388
    2000 519
    2200 660
    2400 845
    2600 1050
    2800 1280
    mas985's Avatar
    Pleasanton, CA
    11,986
    Don't forget that those numbers are dependent upon the plumbing that the pump is running on so it will not be the same for every pool.
    Mark
    Apr 2017
    Maine
    231
    Any difference if wired 125 or 230?
    mas985's Avatar
    Pleasanton, CA
    11,986
    Energy use should be nearly identical for both voltages
    Mark
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    As mas and I said it has a lot to do with the plumbing. At 2500rpm my filter pressure was 25psi and that's a clean filter number. Even as low as 1500rpm I still get 5 psi on clean filter. I didn't look at the pressure at max speed because it was only up that high long enough to get a wattage number. I only have a single 3/4" return eyeball fitting in my pool there is only so much water you can squeeze thru it.
    Not that the voltage will affect the numbers you get, my pump is wired 220v.
    Chuck-
    Does it though? Flow rate will vary significantly based on plumbing. But at the same RPM, wattage will decrease with head loss not increase. BTW: thank you very much for the numbers!
    mas985's Avatar
    Pleasanton, CA
    11,986
    Didn't you just answer yes to your own question? Or were you asking a different question?
    Mark
    Not really. RPM for RPM, the difference in wattage between no flow (0 gpm) and tons of flow (160gpm) in your spreadsheet is less than 2x in all cases. And the difference in wattage between the 0gpm and 50gpm case (normal flow through a residential pool) results in a 30% difference in wattage.
    The difference in flow in all these cases is enormous.
    So, differences in plumbing will certainly have an effect on these wattage numbers, but not a huge one. Good enough that I'd trust them to be applicable to my pool!
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Flow has less effect on wattage than pressure. But yes if you have similar plumbing you will get similar numbers.
    Chuck-
    Rollercoastr posted in another thread:
    I run it at 2,800 RPM which pulls 1,080 watts
    This is very close to what CJadamec posted above.
    Rollercoastr, would you be willing to post more rpm vs watts numbers for this pump?
    TCpoolnoob, have you got yours installed?
    Based on the above, I'm probably going to go with this pump over the IntelliFlo. Also what's good with this pump is it can do basic automation without requiring any Pentair controller components (more $$$$)
    mas985's Avatar
    Pleasanton, CA
    11,986
    If you want to know the wattage at any RPM on any type of plumbing, you can use the spreadsheet in my signature. You can even estimate the plumbing curve for your own plumbing to get more accurate energy use for your situation. Plus you can compare the economics between multiple VS pumps.
    Mark
    May 2016
    West Bloomfield, MI
    757
    Here's my data from my SuperFlo VS today. I can't explain why it's using less power than the last time I looked... the water is warmer, but pressure is higher, as I've added DE to my sand filter...
    800 107
    900 120
    1000 132
    1100 145
    1200 163
    1300 182
    1400 202
    1500 227
    1600 225
    1700 291
    1800 330
    1900 375
    2000 424
    2100 478
    2200 537
    2300 602
    2400 670
    2500 750
    2600 837
    2700 925t
    2800 1030
    2900 1141
    3000 1255
    3100. 1418
    3200 1560
    3300 1689
    3400 1825
    12,000 gal Diamond Brite indoor​ pool. Pentair Triton TR-60 Sand Filter +added DE, Lochinvar Energyrite ERN-200 gas heater, Pentair Multi-valve, Pentair SuperFlo VS pump, TF-100 kit, Pool Math App - iOS
    Warmer water is less dense and will use slightly less power at the same flow rate.
    Higher pressure will slow flow rate and reduce power usage.
    Support the site
