Basically, most of the bad reviews just say do not use the hoses that comes with it.
That one is about $50 cheaper directly from in the swim. There is also a 2 speed version- I’m hunting for it nowNeed opinions on this one, y’all!. It’s 150 sq. ft with a 1.5 HP pump. Comes as a set and fits my budget.
Hayward W3CC15093S XStream Above-Ground Pool Filter Pump System, 1.5 HP Amazon.com : Hayward W3CC15093S XStream Above-Ground Pool Filter Pump System, 1.5 HP : Garden & Outdoor
I was looking for a two-speed version but couldn’t find it! Please let me know if you find one. Thank you!!That one is about $50 cheaper directly from in the swim. There is also a 2 speed version- I’m hunting for it now
Hayward W3CC15093S X-Stream 150 sq. ft. Cartridge Filter with 1-1/2HP Above Ground Pool Pump - Limited Warranty | In The Swim
Hayward W3CC15093S X-Stream Cartridge Filter 150 Sq. Ft. with 1.5HP PowerFlo Matrix Pump Combo provides superior filtration for above ground pools.intheswim.com
Do you have any trees that directly dump to the pool or is it more of a blowing in the wind thing ? I ask because we can size you similar to mine was, and this one is even larger than that. But if a tree(s) has direct dumpability, it has to catch a larger amount of crud than your surface area would suggest. Therefore it would need cleaning more often and not be large enough.Need opinions on this one, y’all
Ahhhh!! I’m rubbing off on you!! LOL! I need to stop too but gotta get my equipment before the crazy folks buy it all up lol. I’ll easily be able to make my money back after selling both of my Intex sand filters and pumps lol! That’s how I’m justifying it.Yeah, sand works fine here since I never have to move it! I think I want 1hp 2 speed pump, and a larger filter than I have now. I too have been going down the rabbit hole looking - I need to make myself stop!
Not directly, no. Only if it’s super windy.Do you have any trees that directly dump to the pool or is it more of a blowing in the wind thing ? I ask because we can size you similar to mine was, and this one is even larger than that. But if a tree(s) has direct dumpability, it has to catch a larger amount of crud than your surface area would suggest. Therefore it would need cleaning more often and not be large enough.
Ok then I’m sold. For regular day to day filtering it would be great. The wind will spread any fallings out fairly instead of gravity punishing the filter on a calm day.Not directly, no. Only if it’s super windy.
The FALL is when there’s tree issues since I close my pool super late. I stay on top of scooping the leaves out and emptying the skimmer basket throughout the day, though. I also have a “leaf net” cover thing which helps quite a bit. But man, those windy fall days are a serious PITA lol. I closed the first week of November the past two years.Ok then I’m sold. For regular day to day filtering it would be great. The wind will spread any fallings out fairly instead of gravity punishing the filter on a calm day.![]()
It seems like folks on here are about the brand names but I’m still new to this. When shopping for filters and pumps separately, how do I know if the two are even compatible? I also am on a budget so I don’t want to go over $700 total for both. Ideally, I’d like to keep it at or below $600-650.No luck finding the 2spd version as a setdoheny’s has the pump but doesn’t sell the filter separately- I dunno if their brand filter is something u would want?
Leaves won’t be an issue with any filter. The pollen in the spring is your properly sized concern. The pollen itself wasn’t even that bad. It was the long stringy flowering snots that my oaks dropped. I always cleaned my filter once the pollen/snots were done and cleaned again at the end of the season to store the cartridges.The FALL is when there’s tree issues since I close my pool super late. I stay on top of scooping the leaves out and emptying the skimmer basket throughout the day, though.
The pollen wasn’t that bad at all last season in central Ohio. Hoping it’ll be the same this year! And if you don’t mind me asking, what made you switch from cartridge to sand?Leaves won’t be an issue with any filter. The pollen in the spring is your properly sized concern. The pollen itself wasn’t even that bad. It was the long stringy flowering snots that my oaks dropped. I always cleaned my filter once the pollen/snots were done and cleaned again at the end of the season to store the cartridges.
Worst case scenario is you have to clean the crud off once or twice in the spring and be good for the rest of the season. If that’s the worst thing that happens each year, it’s a good year.![]()
We moved and inherited it. It’s a 17 ish year old semi inground with original tired equipment that needs a new liner and I can only imagine what the walls will look like at that point. So we planned on gutting it and starting over either way.And if you don’t mind me asking, what made you switch from cartridge to sand?
Need opinions on this one, y’all! It’s 150 sq. ft with a 1.5 HP pump. Comes as a set and fits my budget.
