I have a 3 filter cartridge system. When pump is pumping air pressure builds up in filter tank hence lowering the level of water in the tank and therefore reducing the efficiency of the filters. To eliminate this problem I bleed of a small amount of air/water from the top of the tank. This is not an efficient way to keep the tank full. There seems to be no place for the air to come from. Could it be cavitation of the pump ?
