Sand is brand new as is the lateral assembly. I think I mentioned that in the first post, but I know it was alot of info to digest. Thinking like you, I did a deep clean but when removing the multiport, the main pipe was stuck into the valve and ended up pulling the laterals up enough that one cracked. So long story short, I emptied the sand filter and bought a new lateral assembly. Put new sand in. So sand is clean. My new pressure gauge is due Saturday, so hopefully have a better picture on possible restriction. But unless I did something wrong on adding sand, not sure how it could be filter. I emptied filter, installed lateral assembly, flipped them down, filled half with water, added sand amount according to Hayward manual, which was about 2/3 full.
Curious, is it possible to have too much sand. I would estimate the sand level is about 10 inches below the top...just past the point where the filter begins to narrow towards the top.
