My pump wasn't priming, so I checked all valves and o-rings. Now I can't figure out which positions the valves should be in to go back to normal operation.
I have a pool and a spa, which is higher than the pool. In the current positions that are pictured at the link below, water pours from the jets into the spa, but it doesn't fill up. The water remains at pool water level. The pool is chlorine, and we don't use the salt cell pictured.
I recently moved into this home and I'm not sure what each pipe goes to, as nothing was labeled, or labeled very well.
I labeled each valve in the photos. Can somebody tell me how each one should be set for normal operation, so both pool and spa are full with the pump on or off?
Photos: https://imgur.com/a/pj3yr
