I recently installed a solar heater system to my pool. I have a question about the using the three heating systems when heating the spa or pool. Before solar, the heat pump was enabled as the priority heater. Both the heat pump and gas heater would come on together to heat the spa. Once hot, the heat pump would keep it hot. I never want to ues my heat pump or gas heater to heat the pool. I want to only use solar heat to heat the pool. I’ve enabled "solar priority” to heat the pool when the sun is hot enough for solar. Now it seems the gas heater runs all the time to heat the spa and the heat pump is the secondary heater.
How can I configure my AquaLink controller to only use solar on the pool and use the heat pump as the priority heater with gas back up only on the spa? I use the “One Touch” feature when I want to heat the spa. Thank you in advance for your help.
