- Jun 2, 2021
- 6
- Vinyl
- Pentair Intellichlor IC-40
I am sure that this has been asked more times that not, but I am not very good at searching and locating information on a chat board!
I am getting ready to open my pool and I just want to make sure that I am doing things in the correct order, so if you all could let me know if I am not correct in my assumptions, it would be greatly appreciated.
I appreciate the feedback, instruction and advice.
- Remove/clean/store the winter safety cover
- skim and debris that might be floating on the top of the water
- install plugs, eyes and all other parts that were taken off for winter storage
- Fill pool with water to get to the center of the skimmer
- Prime and turn on the pump to get the water moving and keep it running through the end of this process
- Is this just via recirculation, or should it be going through the filter
- Should I draw water from the main drain or just via the skimmer since I have not vacuumed the bottom of the pool yet?
- Should I vacuum before moving to step 6?
- Balance for pH, alkalinity and calcium
- Santize/shock
- Vacuum floor of pool to waste to clean and clear the pool
- Add water if necessary, re-test chemical levels, add additional chemicals if necessary
- Enjoy! (when it gets a bit warmer!!)
