Hello. I've searched for this issue, but unable to find information per my issue. I have an easytouch system controlling my pool and spa. It has worked relatively well since I had it installed, except for a few actuator issues. The easytouch allows me to use the wireless remote to turn on SPA (as well as other items), and when I do, the heater turns on to heat the SPA accordingly. When I turn off the spa the heater also shuts down. However, when I replaced the last defective actuator I placed the heater into standby mode from the heater control panel. It has 3 modes, Standby, Pool and SPA. I believe it needs to be in pool or spa mode for the easytouch to control it. So when done with the actuator, I tested everything and all seemed to be working well. However, when the pump turned on the next morning, the heater came on as well. I have looked at the settings for the pool and spa heater from the easytouch and I think everything is correct (and as it was before I changed the actuator). It seems that leaving the heater in either pool or spa mode will result in it running whenever the pump runs, regardless of whether I turn on the spa ..in other words, the heater runs whenever the pump runs. Ive looked at the temp settings and the pool temp is warmer than the heat setting AND the heater mode is set to off in the easytouch. Im pulling my hair out because everything did work and I know changing an actuator should have had no effect on heater. What am I missing ?
